^_^ I use white cotton (I kinda could do with a finer grade but no real need) and use a inkjet printer cause I'm not fantastic at doing the banners by hand. Also allows for a bit more detail really. This one I also took a lighter to to give it a bit of a older slightly burnt look. because it was ^_^ Oh and I normally then paint the back of the banner too.
If you wonder, there is some stuff I can't remember the name of right this moment which is basically like a plastic grease proof paper which you iron the cotton to, and it sticks well enough to go through a printer, then you just cut and peel. I picked up the idea some time back from someone that used it for custom doll clothes when they want a certain pattern on them.
