    2026 2025, 2024, 2023, 2022, 2021, 2019, 2018, 2017, 2013, 2012
GG 2026 [Warfork Fantasy Battles] Yellow Toe Nail and Fleabite Worm
This thread is part of the Golden Goblin painting competition 2026. Please see the entry thread for full details.
My Golden Gobbo Experience 2026 entry is my Orc Shaman on Wyvern, from my ongoing [Warfork Fantasy Battles] New Year's resolutions 2025 - The Battle for Arduthrond Glade project.
What I did so far:
Now I started to paint the model, both for Orctober as well as Golden Gobbo:
While Yellow Toe Nail and Fleabite Worm consist of two models (the wyvern and rider, plus the rider on foot; actually three models as the rider is detachable), for Golden Gobbo I enter only the mounted shaman on wyvern, as per the competition guidelines.
For the background story of Yellow Toe Nail and Fleabite Worm, see the Scenario Description.
I tidied up the overspray by brush and gave the base a nice dark bown coat.
tiny
view full sized image [4,032 x 2,268, 1.6 MB]​
I had started to paint the Yellow Toe Nail, when my Deck of Many Colors (by Ninjon) arrived. Flipping through it, I found a card that nearly matched my colors chosen – the yellow was missing, but based on that card I added blue to my palette, a choice I wouldn't have made myself. Already worthwhile, the investement :-)
The wyvern had gotten a coat of gloss varnish two days ago, and was now covered in oil paint.
I used two different greens mixed with violet; one for the scales, the other for the rest of the green areas. The wings got magenta, to give them a "skin hue". The belly section got brown.
After about 40 minutes, I wiped the excess off.
I hightlighted the underbelly with horizontal stripes in Golden SoFlat Titan Buff.
I highlighted the wings along the folds, sometimes in lines, sometimes in stippling, with Golden SoFlat Titan Mars Pale.
The horns around the head and the big stinger at the tail got a first coat of Golden SoFlat Permanent Yellow.
The eye was basecoated in Golden SoFlat Dioxazine Violet.
Over the purple eyes from yesterday, I painted with Golden SoFlat Bismuth Vanadate Yellow, followed by adding Schmincke PRIMAcryl zinc white.
I added Golden SoFlat Titan Violet Pale to the wings, but only to upward facing areas, as a final highlight.
The mounth's inside was painted in Golden SoFlat Dioxazine Violet Deep mixed with Golden SoFlat Fluorescent Violet. To the mix I first added more Fluorescent Violet, then zinc white. Over the tongue I then glazed Golden SoFlat Fluorescent Pink, before adding final highlights to the tongue by adding zinc white to the pink.
The horns on the wings, the claws on the feet, and the teeth, I basecoated in Golden SoFlat Dioxazine Violet Deep, then added Golden SoFlat Titan Violet and started to paint stripes from top to bottom. The same, in smaller stripes and not as far down, I did by adding zinc white in two steps, before adding a final white tip and only short lines with Golden SoFlat Titanium White.
The horns at the head and the bulb at the tail end I had painted in Golden SoFlat Permanent Yellow yesterday. Building on that, I applied slightly watered down Golden SoFlat Pyrrorole Red at one end, slighty watered down permanent yellow at the other end, then wetblended the two.
I then used Golden SoFlat Bismuth Vanadate Yellow mixed with Schmincke PRIMAcryl zinc white, and drew thin lines from the top of the horns towards the bottom. With the big bulb at the tail, i painted in some dots to create a kind of texture.
Finally, I mixed Golden SoFlat Pyrrorole Red with a tiny dot of Golden SoFlat Dioxazine Violet, and glazed a darker horn bottom, where they meet the green.
The scales down the back, I had applied the colder green oil wash. Staying with that, I hightlighted the scales by painting stripes towards their tips in Golden SoFlat Permanent Green mixed with Golden SoFlat Titan Green Pale, in several layers adding more titan green.
Last highlighting step was the scales washed with the warmer green oils, the round ones, and the remaining green skin.
For the round scales, I used Golden SoFlat Light Green Yellow, and then on more selected, upwards facing areas Golden SoFlat Yellow Green on top.
For the rest of the green skin, I used the last airbrushed green (Molotow universes green) mixed with Schmincke PRIMAcryl zinc white.
With the wyvern now also mostly done, it is time to tackle the last major part of the model, the banner. I traced the classic Orc Shaman banner from the 4e army book in Inkscape, mirrored it, just to have it somwhat different, and made the two halves as wide apart as fits the pole I have on my model. The first test showed that the size is about right.
I then put tape on my cutting mat, so that the banner (again from dried wet cloth) will not stick to it. I then taped the dried wet cloth on top, then cut out the banner and taped the frame on top of that. This will be my canvas.
From the cut out banner, I cut out the icons.
Using the paper as a stencil, I dabbed on purple.
I then blocked in the main coloured areas.
To get the paint to soak better into the cloth, I thinned it down with water, so the whole banner currently is still quite wet. This needs to thouroughly dry, before I can continue.
I applied the first base cover layer.
Coming back to the flag, after tidying up the outlines – well, as best as possible. The drawback of using something that looks like actual fabric is, it actually is real fabric. This means you have threads, and some depressions between them, some stray hair standing up… So drawing a straight line often does not work, because it gets interrupted all the time. So it was more dabbing on small points, when I tried to create a certain shape.
Anyway, after tidying up the outlines, I started to paint in the details, leaving the purple outline. The four fields of the flag were then also separated by purple lines.
Using another cutout flag, I inserted into the canvas, I then cut out the center areas to represent the straps. This was also done in small cuts, as dragging along the lines might also rip rather than cut the fabric.
Then, the whole flag was cut out.
I then had an idea, that never occured to me before. I still had the Kraut-Tac base glue in front of me. This is a kind of glue, which is super sticky, and never fully cures. It dries to a rubber like consistency, which never looses its tackiness; similar to the stuff freebies are attached to the front of magazines with.
The idea is, to glue the flag with that glue, then shape it (as it will still be flexible), then use the base fixer from Krautcover (to my understanding a PVA/ISO mix, basically) to harden the shaped form.
Let's see how this turns out. So far, I used a thin strip of Kraut-Tac to fix the ends together, then I attached the rear to the pole with drops of superglue.
So far, the middle of the flag is not yet glued, this will follow next.
The wings and belly used the same base tone (the belly starting from a darker one; both being highlighted differently), and look too much alike for my liking. So I appylied an oil filter over the wings, get them look a bit more leathery. For that I used a thin coat of Winsor & Newton Burnt Sienna with a bit of Winsor & Newton Magenta added.
The flag was glued the rest of the way with the basing glue, the wraps around the pole with tiny drops of superglue, where they did not conform to the form of the pole.
I did the rest of the base cover, then drenched the bases and the flag in AK Interactive Gravel and sand Fixer.
