Mr Papafakis
weismonsters":1wf2ypd9 said:Just one thing- may I suggest a 50mm round base for the dreadnough.
Didn't notice that, but good point Weis
Bugcatcherjp":1u8h0pag said:Ooooo, I've used 60mm on mine but 50mm definitely sounds like the one! You've got me wondering if i should rebase
AndrewMay":363of43j said:Thanks guys!
Hmm..... I remember old 40K large figures having square bases?
Edit:
Just like that^^^
Legiocustodes":16difv3z said:Dreadnoughts and larger models didn't get round bases until the transition to third edition in 1998... though even this took quite a while as most of the second edition models and their Square bases endured until the early 2000's.
All my RT and second Ed walkers are mounted on square bases in order to keep them accurate to their original time.
ramshackle_curtis":1rhmkb9f said:Please note that the dreadought with the bolters has a jump pack as standard equipment,m it may be worth adding one to the model?
AndrewMay":2h6zrdux said:ramshackle_curtis":2h6zrdux said:Please note that the dreadought with the bolters has a jump pack as standard equipment,m it may be worth adding one to the model?
Really?![]()
I'm glad you caught that because I was so awe struck and the kick assness of it that I didn't bother to read the text and was about to ask where all those bits came from!optimus":efkgtyhe said:So you sculpted up his arms, face and accoutrements? Kick arse man!![]()
ramshackle_curtis":1gk3643r said:Contemptor: Standard Sensor Package, Jump Pack, Power field with sychroniser. 4 bolt guns WITH targetter, and BS6.
Dreadnoughts are heinous! We usually play using T8 power fields instead of T10.
