90's inspired 40,000 terrain
The non-rocky areas were basecoated in a dark brown.
view full sized image
I the following picture, you see the difference between Paepercuts Scenic Glue Recipe (which I used on the other terrain, so far) and AK Ineractive's Gravel and Sand Fixer; the scenic glue does darken the sand quite a bit, the Fixer keeps the original colour without any darkening. As I used the Fixer on all the Star Wars mini bases, I think I will need to use it as well at least on the top of the hills...
Here you can see, that the first layer of sand did not cover very well, so I had to apply a second layer, hiding my experiments.
Here are the hills after a second layer of sand.
I've just read through this post from the start - some very inpsiring base work. I've always much preferred this 90's style of home made terrian and you've taken it to another level - fantastic!
As mentioned in the first post of this hills subproject, I planned to store the hills in an A3 box. I don't have A3 boxes, only A4 sized ones, so I cut off the sides of two A4 boxes and joined them. The bottom MDF sheet is glued into the box to get a strong and sturdy box bottom. For the vertical spacers, I used ePVC as well.
Under the second and third MDF board, I glued strips of doubled-on-themselves packing tape to use as handles to lift the boards out.
Having a good way to transport stuff is really important and planning your stuff out so it fits in the box to begin with is really quite smart. Lovely stuff!
[SiFi] 90's Inspired Woods
Anybody remember the 90's, when woods on the tabletop were not just another plastic kit? Where you used model railway trees, or even built them from scratch?
My terrain set needs woods. Well, sort of. With the desert/arid terrain I am building a proper wood, with lush green trees would not be fitting, but some area terrain with tall growing plants - let's call it a wood.
The wood needs to look good, and be playable - so I need removable trees. I based all the terrain from this set on 3mm ePVC sheets, so I started thinking how I could embedd tree bases into that, without bulding another layer on top of the 3mm.
Then, by chance, I received an advertisement mail from Kromlech, for A4 sized ePVC sheets in different heights. 2mm + 1mm is about three, so I bought a couple.
The plan now is to drill holes in the 2mm thick sheets, which takes a washer nicely, and glue the 1mm as bottom below. The washers will allow for magnetic storage of the trees.
After two test drillings, I found a fitting combination of washer and drill bit (they drill slightly larger into the ePVC than their nominal diameter).
I then planned out four sheets, which will all fit together with the trees in one of my storage boxes.
As the test showed, it is not a good idea to drill through the ePVC from one side; rather I slightly drilled into it, then reversed it and drilled the rest from the other side. This resulted in less frayed edges. Except where I pushed too hard and did push through from one side - happened on each sheet.
My next job is, to drill all the rest of the sheets, and then sand the edges, before gluing on the bottoms. Let's get cracking...
In case you want to try this at home, a word of warning. Drilling into the ePVC gets quite messy, that is the reason for all of the background in the pictures being newspaper.
Watching with interest as I was planning to make up some woods myself and was wondering about either doing removable trees on a base like you are doing or if I'd just do several small "bits of woods" that could be placed near to each other.
This is gonna be great... :)
Now I feel under pressure...
Puh, now I am not feeling under pressure any more.
Even if I botch my project, Eric will have learned something from my endeavours.
Construction of the bases is done. I cut the shapes out of the sheets roughly with a saw first, to get rid of the larger edges, then with a craft knife, before bevelling the edges in two to three stages to get nice, rounded edges. Finally I sanded the edges, as well as roughened the top with sanding paper for a better paint adherence.
Next up is constructing the 'trees' and some undergrowth.
Looking like an excellent forest there man!
Debate between fixed trees and modular is interesting.
I think for playability modular is likely a better option, though not sure if I really have much of a say in the argument without any woods of my own
Looking forward to seeing how you make up your trees and undergrowth :)
