well, i've had a bit of a time with my deadcember contribution. i decided to go with the fenryll armee de squelettes i picked up in september 2016 from battlefield berlin. these are twenty multi-part resin figures comprising four each of five different torso and legs, four each of five different weapons with the right arm (axes, broadswords, falchions, morning stars and spears), four each of five different left arms, four each of six different heads, four each of four different shields, and twenty 20mm square resin bases. they were quite fragile and prone to snapping at ankle, waist and wrist when being removed from the sprue. they also proved temperamental when being glued; super glue usual worked, but the occasional bond just refused and required uhu. uhu didn't work most of the time however, and plastic cement was right out.
i went for maximum variation in the combination of parts and then painted them up in batches of five each with a different weapon, using a different off-white (brown, cream, green, grey) for the bones of each batch those this isn't very obvious on the finished figures.
here they are grouped by weapon type, and then as a block (split across two posts). obviously, i'll actually be fielding these as part of units of equivalent weapon types when they see action in my undead army.
