Re: Marienburg vs. the Undeadish
zoggin-eck":3uki5nqe said:
The table looks great!
Is that a Forgeworld Teclis used as a statue?
Also, have we seen a close-up of the War Wagon?
Thanks. I believe that's the FW Teclis. It was glued on a plaque & painted gold, as an award from a tournament long ago. It was in storage and broke in several places, so I pried it off & used it for terrain. Marienburg & the Wasteland were supposedly settled by elves in the very distant past of the Warhammer world, so I like the idea of having some ruins in what has since become blighted fens & marsh.
Here's the rest of the unit of old dwarf spear/pike:
And the now completed Westfalia halfling:
I've been experimenting with more terrain. This was done with a bit of pulled apart steel wool, glued to a base, sprayed with brown primer, and then glued with some clump foliage.
As posted elsewhere, I picked up this "Lord of the Feast" from Hordes.
And this is what it looks like out of the package:
I've got conflicting feelings for it. On the one hand, I love the figure and it's well sculpted. I also like the size (for my project) which is significantly taller than a normal human. I will have to dig up the figure, but I think it should look good with the old Citadel "Death Elemental." But on the other hand, it's seven pieces with mostly bad glue-joints, and little opportunity for easy pinning. It looks like it will fall apart if used for actual gaming. My experience with sculpting, mold making, and casting is admittedly limited, but I think this really could have been designed with better joints and/or in fewer pieces. I go this because I was excited to work on it next. But right now I can't work up the enthusiasm to try putting it together properly.
