• On Wednesday 18th Feb the board software will be upgraded. Whilst not much will change on the surface it's a reasonable change under the hood. The board will be offline during the upgrade to make life easier for those doing the update! It'll take an hour or two.
Michaels 25mm WFB Stuff...
Interesting, though that bit goes on the inside so would not be seen?
Yep, metal pin on door frame/upright goes into housing into beam lintel above, and ditto into stone slab/flag at base. Handy as heavy barn Door leafs can swing either way in or out, and strong. It's a nordic thing 'oop here in Cumbria...
To expand on my comment, our splashbacks' are simply 12" or so of smooth wall painted black below the render. The idea being, I assume, that muck thrown up by heavy rain doesn't show up as much as it would on paler walls.
Oldskool way of damp proofing real life! Black bitumous paint/ tar as water-proof 'tanking', often 'acquired' from Naval yards back in the day. Water splashes up from hard/compact surfaces, so you need to protect timberwork from rot and then insect attack. Modern waterproof paints mimic. On stone buildings tends not to be used (maybe on brickwork on occasion) as proper Lime render/pargetting is breathable and drys out naturally. Otherwise it was a coating of Limewash (traditionally coloured with Ox blood and/or earth/clay pigments for pinks, oranges, browns, etc- not all white like the chocolate box cottages here in the Lakes. This was for water-proofing any Lime render, a sacrificial and sterile wash basically, reapplied year and year on by farmer houseowner. Sorry for going on a bit... :grin:
No, just Zinsser AllCoat. That said, it's a 20th century building with a 21st century extension & anything nasty will have been long banned. FWIW, years ago my folks had an old thatched timbered house in the Home Counties. White walls, no splashbacks.
