Michael Stockin
I have a small offcut I can send you if you like?
Thanks. Not sure if you think 5 hours so far is quickly or unquickly?
My first thought on seeing this was an image of Jack Nicholson and "all work and no play makes Michael a dull boy!" But I can see how you you could get into a zen flow state with the repetition 😂
Have seen some crafters rough up balsa beams with a wire brush beforehand to create a bit more texture?
That material sounds great, will have to seek out some when in the mood for crafting buildings!
I get it. I've got a 3d printer to do terrain bits, but I'm thinking mostly for complex pieces or for bits that can stand in until I've made my own by hand. There's a joy in craft that goes beyond just creating the final itemYou know, every now and then you split it wrong and you only get 1 shingle and some waste, but every now and then you get a really interesting split that has an interesting shape about it.
At the risk of being pretentious, I feel more like a craftsman having to cut every bit to suit, feels more of an accomplishment?
Simple things amuse simple minds?
Totally agreed, my scenery may be crap, but it's MY crap that I made.There's a joy in craft that goes beyond just creating the final item
At the risk of being a mad fanboi, it is like a wonder material. The only possible negative is that liquid poly glue does not work.
File it, sand it, cut it, glue it, spray it, engrave it... marry it?
By the way. Does anyone understand the door configuration on this thing?
The arch leads to the stables. Under the arch is a door into the inn. Is this the main door?
What are those double doors? Are they at the rear or the front of the building?
On the other side of the building from the double doors is a single door, is this the front door?
It could be a way in from the stables but the door under the arch would do.
Why is there no gate on the arch?
Who designed this?
Oh. Ha ha. I will go check out The Riding. BRB.
I love a good stream of consciousness ramble.. prone to them myself 😂
