Here is something a little fun... maybe...
Heroquest uses 20x25 mm bases, which is a pain cause the squares are 20x20 (roughly).
okay, that's no problem.. But then you get WD quests and stuff which say 'Hey, Use a Rat Ogre'.. which are on 40x40mm bases. Is it possible to stick a Rat Ogre on a 20x20mm base? … kinda. just not very well.
So then there is a small issue.. If you want to use a quest with a larger base figure like a Ogre, Rat Ogre, Troll etc, you can either base them bloody small and kinda ONLY use them for Heroquest... or you can normal base them and try to figure out how the hell you can use a 40x40mm base to take up 1 square on a 20x20 square grid..
So I ask "What do people do?" Sure, you can say "Well, for Ogres, just use the Ogre Hoard ones" but that's not dealing with the problem, just passing it along for one case. I guess the same things would apply for AHQ and WHQ.. So, whatever your quest, how do you deal with base problems like this?
