KingOfTheLeadPile
I wanted to do an Orctober for several years now, but always, October was sudddenly there and I had a pile of other projects ongoing, so I said "next year" again and again.
This year I started as early as February to be prepared.
I got a Dwarf Army consisting mainly of Battle for Skull Pass miniatures, which are not true mono pose minis, but close to them. I bolstered their ranks with some EM-4 Plastic mono pose Dwarves. Ever since (2007-ish or so), I wanted to get their Orcs as well; especially as from a fluff perspective, the Orcs are traditional enemies of the Dwarves.
So this year I got 50 Orc Bowmen, 100 Orc Spears and 100 Orc Swords from EM-4. That should be sufficient for a greenskin horde. I planned to convert some of the minis to boar riders, and bought 15 Red Bard Game's Boars.
When checking 3rd ed. Armies for troop choices, I started to look for bits for some conversions. Since I got a 3d printer this year as my birthday present, I quickly found a suitable set of stls on My Mini Factory. I could also just have printed the Orcs from that set, but I wanted to do the EM-4 mono pose guys.
I printed shields and weapons, heads and drums in order to be able to customize all the unit types and command groups I want to build. After some test prints, I settled for printing the bits in 83% size of the stls as bought, that to my eye fits the EM-4 Orcs best.
As I only have a month (which I can easily manage... for sure... I guess... probably...) I am willing to make concessions when it comes to painting. Also the Dwarf force mentioned above, I only blocked in the colors, then gave them a dunk in Army Painter Quick Shade and called it a day. I will go the same route with the Orcs; on the one hand due to time contraints, on the other hand to give them the same general look/style as their Dwarven adversaries.
I also will base these minis on plastic bases, and not on metal bases as I switched to for all my minis over the last years; again for the same reason, to have them look similar to the Dwarves.
So here is the whole project so far. Should be easily managable within one month, right...? For the bases I got every 25mm base out of my box of spare bases I accumulated over the years, but I did not had enough and ordered some additional ones.
As mentioned above, I ordered the Red Bard Games Boars, but the set of stl files also included Boars. And chariots. So I think I will use the 3d printed boars in this project, and base and paint the Red Bard Games ones as animals for handler packs.
The stl bits I printed at a smaller scale, but the boars did look not large enough, for them I will go with 100% scale. Which also gives me more room on the chariots, as I need to print them the same size as the boars. There are a couple different boar sculpts in the stl pack, but this is a monopose project, so I will only print one body/head combination.
To stand any chance of finishing this project in October (which will not work out anyways, but I want to get as much done as possible), I gave me a little head start. I did most of the 3d printing, and I started to remove the flash and the integral bases of the 50 bow armed orcs. One of the good things about post-Covid-mostly-home-office is, that in Zoom/Teams calls where you need to pay attention, because someone might be involving you, you cannot do any "real work" besides where you need to concentrate, I found it is perfectly possible to intently listen to what is being said, while at the same time have your fingers mindlessly remove flash from plastic minis. Doing that in the office would probably also be possible, but I might get some strange glances.
The process will be the same for all the three types of minis. Remove the mould lines, cut off the round thing on their backs (I think it originally was intended to glue shields to, the Dwarves had the same protrusion) and then cut away the base (first with a cutter, then the fine work with a knife).
Here you see some samples of what I printed for converting.
The next 3 days we will be off with my mother-in-law, but a bag of orcs and cutting tools
will accompany me
will accompany me
