Rodor Hammer R: in a country churchyard: renedra and citadel gravestones review / in un cimitero campestre: recensione di lapidi renedra e citadel
Blog: Rodorhammer
Owner: Rodor
Author:
Post: R: in a country churchyard: renedra and citadel gravestones review / in un cimitero campestre: recensione di lapidi renedra e citadel
" where heaves the turf in many a molding heap,
each in his narrow cell for ever laid,
the rude forefathers of the hamlet sleep."
T. Gray,
Elegy written in a country churchyard (1751)
Finally returning to the fantasy world and my band of Nuthgnawers, I would like to present in this post the review of gravestones and tombs that I have selected as elements for the basing. In fact, I planned that about a third of my gnoll/dogman warband will have breached a country cemetery in the northwestern area of Averland, and I therefore collected accessories that would inspire me to create a coherent setting.
J . Constable, "Stoke Poges Church, Buckinghamshire". Illustration to T. Gray's Elegy (1833)
Among the many manufacturers who make gravestones and tombs as scenic elements, I basically followed two criteria in my choice. The tombs should not have been too imposing and elaborate, because I imagined the place of my "mosaic" as a peripheral graveyard and because materially each tomb had to enter together with a miniature on a 25x25 mm base. I also wanted to avoid tombs that had an excessively 'Gothic' appearance (in the literary sense of the term) and that seemed too much the foregone setting of a vampire story.
A) RENEDRA
I therefore focused primarily on a set of gravestones sculpted by Steve May and
produced by RENEDRA, conceived for historical models rather than fantasy.
The set consists of two identical sprues with 28 elements each, which allow the creation of at least 40 burials in total: most of them are gravestones, memorial stones and bases, with even a larger slab tomb. Exceptions are a bird (which should vaguely be a raven) and a milestone.
The strong point is in my opinion that a package offers a very varied set of gravestones in size and shape, so that you can find the one that best suits each miniature. From the following photo we can see how they are perfectly proportioned for a human miniature of 28 mm at eye level - eh, yes... still the Felix of D - and instead appear smaller next to most of the gnolls/dogmen (which, remember, are larger than human stature), but without being tiny.
Five different types of RENEDRA gravestones
My evaluation of this set of gravestones is therefore very positive, even if I have to underline two negative sides:
- (in general) most are carved only on the front side, while the back is smooth. This is fine if the accessory is to be placed on a wall or building, but not if it must be viewed all around;
- (for fantasy) some have clear Christian symbols, having the cross shape or having the cross carved on them. Although the patent cross is an Imperial symbol in the world of Warhammer, for my needs I will have to discard some of them or modify them to make them more suitable for the latter universe.
B) BITS FROM CITADEL BOXES
B1) GRAVESTONES FROM ZOMBIES AND SKELETON WARRIORS
I had the opportunity to add individual bits from other more or less recent Citadel sprues to the Renedra set, and first of all two tombstones taken respectively from old sets of zombies and skeleton warriors. The two types are about the size of the smaller Renedra gravestones, but still appear compatible. Used in combination with the previous set, they introduce further variations and have the advantage of being sculpted on both sides.
Gravestones (from left to right): 1 CITADEL Zombie regiment, 1 CITADEL Skeleton warriors, 3 RENEDRA
B2) TOMBS FROM WARHAMMER QUEST: CURSED CITY
The more elaborate pieces, however, are those of Warhammer Quest: Cursed City, which are not actually conceived as elements of scenery, but as an integral part of the zombie miniatures who carry their ancient tomb on their shoulders. The tombs are certainly attractive for the variety and richness of detail, from candles, scrolls, flowers, up to a crow with an eye in its beak... However, they have the disadvantage of being, like the miniatures themselves, thinner and smaller compared to previous Citadel ones. Also for my needs some tombs have a little rural aspect, and therefore I believe that I will make a limited use of them.
Tombs (from left to right): 1 CITADEL Cursed City, 1 CITADEL Zombie regiment, 1 CITADEL Skeleton warriors, 1 RENEDRA, 3 CITADEL Cursed City
B 3) TOMB SLABS FROM THE SIGMARITE MAUSOLEUM
To conclude, I also wanted a tomb slab that could be compact, but in the meantime a little more elaborate, so as to perhaps distinguish the burial of a more illustrious person from the simplicity of other common burials. I was able to find individual pieces of CITADEL Sigmarite mausoleum, which contain various slabs, broken or intact. Probably part of one of them will be reused for my graveyard desecrated by furious (and hungry!) dogmen.
POST SCRIPTUM: A heartfelt thanks to D for the usual loan of her precioussss Felix, and for taking almost all the photos in the post, using her brand new tablet holder!
______________________________________________________________________
"dove il terreno si solleva in cumuli marcescenti,
ognuno giace per sempre nella sua stretta cella,
dormono i rozzi antenati del borgo."
T. Gray, Elegia scritta in un cimitero campestre (1751)
Tornando finalmente al mondo fantasy e alla mia banda di Nuthgnawers, vorrei presentare in questo post la recensione di lapidi e tombe che ho selezionato come elementi per l’imbasettamento. Ho infatti programmato che circa un terzo della mia banda di gnoll/uomini cane avrà violato un cimitero di campagna nella zona nord-occidentale dell’Averland, ed ho quindi raccolto accessori che mi ispirassero per creare un’ambientazione coerente.
J. Constable, "Stoke Poges Church, Buckinghamshire". Illustrazione dell'Elegia di T. Gray (1833)
Tra i molti produttori che realizzano lapidi e tombe come elementi scenici, ho seguito nella mia scelta sostanzialmente due criteri. Le tombe non dovevano essere troppo imponenti ed elaborate, perché ho immaginato il luogo del mio “mosaico” come un cimitero periferico e perché materialmente ogni tomba doveva entrare assieme ad una miniatura su una base di 25x25 mm. Volevo inoltre evitare tombe che avessero un aspetto eccessivamente ‘gotico’ (nel senso letterario del termine) e che sembrassero fin troppo l’ambientazione scontata di una storia di vampiri.
A) RENEDRA
Mi sono quindi orientato in primo luogo verso un set di tombe scolpito da Steve May e prodotto da RENEDRA, concepito per il modellismo storico prima che per il fantasy.
Il set è composto da due matarozze identiche con 28 elementi ciascuna, che permettono la realizzazione di almeno 40 sepolture in totale: la maggior parte sono lapidi, cippi e basi, con anche una più grande una lastra tombale terragna. Eccezioni sono invece un uccello (che dovrebbe vagamente essere un corvo) e un cippo miliare.
Il punto di forza è a mio avviso che una confezione offre un insieme di lapidi molto vario per dimensioni e forme, così che si può trovare quella che si adatta meglio ad ogni miniatura. Dalla foto seguente si ricava come esse siano perfettamente proporzionate per una miniatura umana da 28 mm all’altezza degli occhi - eh, sì…sempre il Felix di D - ed appaiano invece più piccole accanto alla maggior parte degli gnoll/uomini cane (che, ricordo, ha dimensioni maggiori della statura umana), senza però risultare minuscole.
Cinque tipi diversi di lapidi RENEDRA
La mia valutazione di questo set di tombe è quindi assai positiva, anche se devo sottolineare due lati negativi:
- (in generale) la maggior parte è scolpita solo sul lato anteriore, mentre il posteriore è liscio. Questo va bene se l’accessorio va posto addosso ad un muro o a un edificio, ma non se deve essere visto a 360 gradi;
- (per il fantasy) alcune hanno chiari simboli cristiani, avendo la forma croce o avendo la croce scolpita su di esse. Anche se la croce patente è un simbolo imperiale nel mondo di Warhammer, per le mie esigenze dovrò scartarne alcune o modificarle per renderle più adeguate a quest'ultimo universo.
B) PEZZI DALLE SCATOLE CITADEL
B1) LAPIDI DEGLI ZOMBIE E DEI GUERRIERI SCHELETRI
Ho avuto la possibilità di aggiungere al set Renedra singoli pezzi da altre materozze CITADEL più o meno recenti, ed innanzitutto due lapidi prese rispettivamente da vecchi set di zombie e guerrieri scheletri. I due tipi sono delle dimensioni delle lapidi più piccole del set Renedra, ma appaiono comunque compatibili. Usate in combinazione con il set precedente, introducono ulteriori varianti ed hanno il vantaggio di essere scolpite su entrambi i lati.
Lapidi (da destra a sinistra): 1 CITADEL Reggimento zombie, 1 CITADEL Guerrieri scheletri, 3 RENEDRA
B2) TOMBE DI WARHAMMER QUEST: CITTA' MALEDETTA
I pezzi più elaborati sono però quelli di Warhammer Quest: Città maledetta, che in realtà non sono concepiti come elementi di scenario, ma come parte integrante delle miniature di zombie che si portano sulle spalle il loro antico sepolcro. Le tombe sono sicuramente attraenti per la varietà e la ricchezza di dettagli, dalle candele, ai cartigli, ai fiori, fino a un corvo con un occhio nel becco.. Hanno però lo svantaggio di essere, come le miniature stesse, più esili e piccole rispetto ai precedenti Citadel. Inoltre per le mie esigenze alcune tombe hanno un aspetto poco rurale, e quindi credo che ne farò un uso limitato.
Lapidi (da destra a sinistra): 1 CITADEL Città maledetta, 1 CITADEL Reggimento zombie, 1 CITADEL Guerrieri scheletri, 1 RENEDRA, 3CITADELCittà maledetta
B3) TOMBE DEL MAUSOLEO SIGMARITA
Per concludere, volevo anche una lastra tombale terragna che potesse essere compatta, ma nel frattempo un poco più elaborata, perché distinguesse magari la tomba di un personaggio più illustre rispetto alla semplicità delle altre sepolture comuni. Sono riuscito a trovare pezzi singoli del mausoleo di Sigmar CITADEL, che contengono varie lastre, spezzate o intatte. Probabilmente parte di una di esse sarà riutilizzata per il mio cimitero profanato da uomini cane furiosi (e affamati!).
POST SCRIPTUM: Un sentito ringraziamento a D per il consueto prestito del suo tesssoro Felix, e per aver effettuato quasi tutte le foto del post, avvalendosi del suo nuovissimo supporto per tablet!
Continue reading on the Rodorhammer blog
Please note that any comments you post here about this news feed article may not be seen or ready by the owner of the blog from which the article came.
Please consider visiting the blog itself and commenting there as well to give the author your feedback.
