Building a Daemonic Legion of Slaanesh
Rivetbull
I have been, slowly buying up, and trading for the original Slaaneshi daemons for about half a decade. Some of the daemonettes and one Keeper of Secrets have been in my collection since the late 80s. I began adding to them casually with no particular goal in mind since I moved to the UK in 2014. I began seeking them out in earnest since 2018 after going to (and being inspired by) Bring Out Your Lead that year. Recently, I have acquired enough to get to work on the project properly.
I have been smitten with the bizarre look and feel of Slaanesh since Slaves to Darkness dropped when I was in my impressionable teens. I collected a modest mortal Slaanesh army in the late 80s/early 90s, but what I really always wanted was a Daemonic Legion full of the madness like my teenaged self saw in the Slaves to Darkness tome. However, because of my meager funds back then and the limited availability of those models in the US, such a collection was frankly unachievable for me. As I mentioned I kept some of the models out of nostalgia, and in 2018 I decided to try to deal with this “unfinished business” from my gaming youth. I set about making a plan of what I would need to find to make a reasonably credible and playable list. Honestly though, I have no real expectation of getting to play it. I just need to build it. Turns out just planning a legion was a trickier task than I initially gave it credit for.
When one looks at the descriptions for the daemonic legions in the Realm of Chaos books they will see a lot of randomness and contradictory advice for starting out. Slaves to Darkness states on page 173 that “To start off, limit the armies to no more than 10,000 points each.” but then again on page 176 it states ”A battle with a single 5,000 point legion on each side should last most of an evening. A 5,000 point Daemonic Legion is also around the right size for your first Daemonic Legion battles.” Certainly 10,000 points seems like a tall order when you look at the Army lists themselves and start tallying up unit costs, as that kind of points level isn’t really possible without significant auxiliaries or multiple legions. However, in the Lost and the Damned on page 238 it says that ”3,000 points is the usual yardstick for a Warhammer battle...” and that “we would recommend 3 greater daemons...”. If one ignores auxiliaries and allies, then 3,000 points does give a reasonable distribution of units in a single legion. Therefore, I decided to use 3,000 points of lesser daemon units and three Keepers of Secrets as an initial goal for my Slaaneshi Legion. These should form the core of the legion in any circumstances even if I get more ambitious later. 5,000 points would make for a good list with some basic auxiliaries and mortals added to the core.
The three Keepers of Secrets required would need to be differentiated from each other. GW made the Keeper of secrets modular with two sets each of upper arms, lower arms, and legs. They also made a half dozen different heads. Two of these are undead skulls, which never did much for me. Another, my least favorite, had an eyepatch and pretty small horns. Ironically, “pirate-minotaur” was the only one I ever found when I was a teenager, but I have since corrected that problem and found the three better more menacing bovine heads. Careful choice of parts, and relatively minor conversion work will allow me to make all three Keepers look significantly different, while still using almost entirely classic model parts. The most obvious difference in the three Keepers is that one, and only one, in a Slaaneshi Legion gets a Rod of Command. GW never made a model for the Rod, so I needed to convert one. I settled on using the old daemonette familiar as the basis for the Rod as she is standing straight with her limbs tight together and is small enough to be an implement in the daemons mighty fist. The second Keeper would be the champion or enforcer of the legion. I gave him a pair of chains each ending in a morning star at each end. I used real chains and some plastic chaos warrior maces for the balls. The last Keeper would be the Legion’s Battle Standard bearer. This would require some wrist cutting and converting to get right.
The core of the legion I kept simple and made sure to use all the released Slaaneshi daemon models from the realm of chaos era. I settled on three units of six Daemonettes. Citadel made thirteen sculpts of daemonettes, and I have all of them represented in these three units, as well as some duplicates of my favorites. One will be given a banner, which may or may not have any impact on the table. It certainly won’t be as grand as the Keeper’s banner. Next were two units of six Fiends of Slaanesh. Again, I’ve gone to some trouble to make sure that all the sculpts are represented in these two units. Lastly, I have one unit of six Mounted Daemonettes. This unit was by far the most problematic. Mounts of Slaanesh are simply not easy to come by, and finding six took no small amount of time and effort. In addition, the only daemonette rider sculpt from that era, which is pictured on page 158 of Slaves to Darkness, was never released. Even if it had been, one sculpt repeated six times in a single unit is not acceptable. This meant that I would have to convert riders from the classic daemonette sculpts. The trick here is to choose daemonettes whose tails are well out of the way. I have built a couple so far and it is tricky to model them sitting up straight on their steeds. But, it is already obvious that they will be a striking unit when finished. Together these units weigh in at precisely 3,000 points, and with six units of six daemons each feel entirely appropriate as the basis of a Slaaneshi Daemonic Legion.
The first thing to get painted was one of the Keepers of Secrets. I painted this fella a pastel green with bright yellow contrast on the leather and lacquered horns and such. His schtick is the Legion's champion, and he was given a pair of ball and chains made from modern GW Chaos Warrior maces and some simple necklace chain. I decided to keep the base simple and largely without color to contrast with the riot of colors on the rest of the models. I picked broken flagstones because they are easy and because they can be replicated on a display board at some point in the future.
Next I painted a pack of Daemonettes. I gave each one her own skin color scheme and then used the same bright yellow to tie them together. The flagstone effect was repeated on the movement tray and looks like it is going to be effective throughout the project.
Cheers. I’ll be posting updates as I move along through the project. Next thing I paint will most likely be a unit of Fiends or the next Keeper.
⏲ Please note there was roughly a 5 year gap between these posts ...
Well, I know its been a rather long time, but I’ve been away busily working (sometimes even on the project), and I finally have things to post. I took part in a pair of Old World Army Challenges (2023 and 2025), and at this point I have a solid core to the Legion painted up.
I still have some lead in my warchest, and ideas for some expansions, but this is enough done to claim “I have a proper Slaaneshi daemonic Legion” with a straight face.
I will talk through the units with pics at a leisurely pace. If you are interested in anything in particular, just say so, and I’ll start with that.
⚠ Please note that until the post above this thread had been inactive for about 5 years ...
The best thing about the forum is it's here waiting - drop in as often or infrequently as desired!
And to echo Brother Meredith - what a way to return! Wow, I mean no wonder it took a while, I bet some of the colours there were probably only invented in the last few years! :) Amazing looking army, wonderfully vibrant colours. Those minotaurs look good, like the colour scheme on them. As Old Hob said - more photos please! Some of the beasties you have hidden there in the photos look awesome.
Wow! Lovely stuff, well done.
So the first thing I’ll dive into, I guess, are the core of the Legion, the daemonette infantry. What I wanted from this project was to build a Slaaneshi Legion that feels like what was presented in that most haloed tome, Realm of Chaos Slaves to Darkness. A pic from page 158 shows you what I’m going for. As a result, I went out of my way to NOT to have a unified color scheme. Certain models inevitably shared colors with some of their sisters, but the units are intended to be a riot of soft pastel palettes and bright jarring contrasts. This doesn't mean that the Legion doesn't need to still look cohesive; so, what I did was paint most of the stockings and armor plates in a bold yellow. I only used this yellow as a skin tone on a couple of the Daemonette sculpts, those with no cloth and little armor. The tie back to ‘yellow stuff’ was repeated throughout the Legion whenever it worked.
Games Workshop released a total of 13 sculpts for the initial run of Daemonettes. The original sculpts are pretty varied but still require a fair amount of repeats in order to field 30. I broke this up a bit by doing some simple reposing of claws Lead is great for this kind of thing. I also added some topknots here and there from modern plastic bits. There is still at least one unmodified version of each of the original thirteen sculpts present.
For basing I use a basic sand flock on a 25mm GW circular base. I know this is a bit flashy by the standards of the late 1980s, but I think it just looks better than green grass flocking. Some among you may ask, "But why circle bases and not the good squares that citadel provided?" I have a number of reasons for this change, but the most important is this one...Unit sizes in a Slaves to Darkness Daemonic Legion battle are very small. Most being 6, 7, 8, or 9 models only. The auxiliary Undead and Minotaur units are the only units which can be larger. This makes WFB3 rules surprisingly awkward to run the game. Rogue Trader's core rules for units are actually much more practical. So, not only can the models be used as is in Warhammer Fantasy or 40,000, but the clever use of movement trays allows me to use them seamlessly in other games without issue. They have taken the field in Kings of War, Dragon Rampant, and even Space Hulk so far.
In the end, there are thirty Daemonettes organized into five units of six, each unit is worth 600 points. So, 3,000 points of Slaanesh’s finest for the backbone of the legion.
I think the bases are great, the flowers in particular work well with the Slaanesh I think. The colours on the Daemonettes are great. Thanks for the first of what I hope are lots of lovely detailed photos! :)
Thanks for the votes of confidence. This project was a labor of love that took half a decade of collecting and painting to make real. It really was a bucket list hobby achievement.
I’ll call it a night with a couple more close ups of my favorites of the daemonettes.
I’m going to monologue a bit about the beginning of my quest…
I started with the second edition Warhammer Fantasy Battle back in 1985. By "started" I mean I started collecting models and even painting a few to a questionable standard. If memory serves, I don't think I actually found an opponent and played a game until I was using the third edition hardcover and Warhammer Armies. Then in '88, I was just starting high school and living in the mid-West of the U.S., I acquired Slaves to Darkness and my tiny mind was blown. The crazy in that book left deep impressions, the scars of which I carry still.
I loved everything in that book, but it was Slaanesh and his/her wild color schemes made without pattern or constraint that really pulled me in. I managed to cobble together enough models to play a modest chaos army, but what I really wanted was to assemble a daemonic Legion. But I was a mere teenager, my funds were limited, and in the midwestern US the acquisition of proper Realm of Chaos daemon models was problematic. At most, I cobbled together a unit of Daemonettes, a couple of Fiends, and single lovely Keeper of Secrets. Oh, I had plenty of champions and beastmen and monsters, but these were all the extras in a Daemonic Legion army, or "Auxiliaries" as Slaves to Darkness called them. Then I went off to college, started playing more and more 40k, and eventually went off to the military, and in the process lost most of my toys. I recovered that single Keeper from my folk's place and one of the original, very poorly painted, daemonettes from an old college buddy, years later. These mementoes of long abandoned ambitious sat quietly in a box for many years.
Then in 2017, after having stumbled upon ‘Bring out your Lead’ while living in Lincoln, UK. The sight of so many outstanding relics and legends of hobbying got me dreaming again. By 2020, I restarted this childhood quest with a good deal more patience and significantly more funds than I had possessed in 1989. The old Keeper and his handful of followers were stripped bare, trades were arranged, and ill-advised purchases made. When I had enough, I joined the Old World Army Challenge and got to work.
I missed the original post because I'm relatively new to the forum, so thank you for adding more info and resurrecting the thread. I appreciate it as a Slaanesh connoisseur & collector. I think you'll appreciate this for inspiration to paint your minotaurs and KOS.
Keep us updated with more models, please!
Thanks for the kind words.
Nice model. I also have that guy. I used the model to make a rather gangly daemon prince. I used a Die Hard familiar to be his little buddy. What she does for him is probably not worth dwelling upon. The shield is a bit from my box. Not certain, but I think it came from a WarMachine model. Folks might recognize the sword. It was a halberd on a kinda dumpy bald Slaaneshi champion. On the daemon prince its a nice longsword. Lastly, the wings came from a lead bloodthirster. The irony of that is delicious.
A spectacular army! There's so much to discover, that full group shot of everything is like a Where's Waldo of awesomeness.
I'm curious to learn more about kinky Chaosette with wings and claws there in the van. And murderdeath demon bunny monster next to the Jabberwock and their pal sixlimbs. Oooh! And what's that weird gear the skeletons are toting and who are the panzees in yellow and pink?
nah, I'll just wait for you to upload whatever you want to show, cheers
