Base sizes for Nippon?
Should be in the main WHFB book mate (its not listed in the mercenaries section of warhammer armies)..
Pretty sure the hobgoblins are 25mm
MD
Nippon are standard humans so 20mm, and Hobgoblins in 4th/5th are on 20mm not sure about 3rd.
Thanks for the info guys.
One reason for asking about the Nippon is that I have lots of the Clan War range of miniatures.The bases they come with are 25mm one's.LOts of the sculpts will struggle to go onto 20mm bases due to the wide leg stances.
Aiteal mentioned that he uses 25mm bases for his Hobgoblins.
The larger base size can only be a disadvantage for you so no one with a brain is going to complain when playing you. Also the "or as appropriate" thing they used to add to the larger based models (monsters etc) applies - if 25mm is the smallest size the model can properly fit on it seems an exercise in futility to try and cram onto 20`s.
The only other way around it is to multi-base the ones with wide stances. ;)
